5 members (tclederman, DadsFirstPickup, 59 fleet, IHPWR, Ponchogl), 102 guests, and 4 robots.
Topics128,107
Posts1,056,225
Members48,436
I posted a question to the engine and driveline board earlier and came back expecting to find responses with help to my problem and found it to be closed. It was regarding a brake mounting question so I thought it was the best forum to ask on?
Because the question concerned a modification to a Big Bolt, it got moved the that forum. Check it out, you have a couple of responses there.
Bill Burmeister
the moderator "causes" it .... and should explain, IMO ... he prolly felt it shoulda been in the hi-po forum, considering it wasn't really to do with the old truck as much as the newer modifications ohwell
and in the case of being moved it should especially be explained!
I just found it, I guess I just figured since it was a brake question it belonged there. My mistake. Thanks all.
first time I seen one locked out, they sometimes move them from place to place without saying and then sometime they will email you saying your post has been moved.....dont worry about it,, just keep on posting....
Redryder pix
My Hotrod
Boards that I moderate on say that the mod needs to leave a reason why the action was taken. But we sometimes get overwhelmed.
Fred
52 3600
69 C-10
Us moderators are the guilty ones. Our software is set up to lock the thread when it gets moved, and sometimes we forget to put the reason or place we moved it to before we lock the thread. Its a pain to unlock it to fix. Sorry we confused you.
Paint & Body Shop moderator
