7 members (Charles in CA, LAROKE, Wally / Montana, Cletus1950, 78buckshot, TrknGMC, UtahYork),
137
Mod | | | Forums66 Topics128,107 Posts1,056,221 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 117 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 117 | I posted a question to the engine and driveline board earlier and came back expecting to find responses with help to my problem and found it to be closed. It was regarding a brake mounting question so I thought it was the best forum to ask on? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Because the question concerned a modification to a Big Bolt, it got moved the that forum. Check it out, you have a couple of responses there.
Bill Burmeister | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the moderator "causes" it .... and should explain, IMO ... he prolly felt it shoulda been in the hi-po forum, considering it wasn't really to do with the old truck as much as the newer modifications and in the case of being moved it should especially be explained! Bill | | | | | Joined: Oct 2006 Posts: 117 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 117 | I just found it, I guess I just figured since it was a brake question it belonged there. My mistake. Thanks all. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | first time I seen one locked out, they sometimes move them from place to place without saying and then sometime they will email you saying your post has been moved.....dont worry about it,, just keep on posting.... Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Boards that I moderate on say that the mod needs to leave a reason why the action was taken. But we sometimes get overwhelmed.
Fred 52 3600 69 C-10
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Us moderators are the guilty ones. Our software is set up to lock the thread when it gets moved, and sometimes we forget to put the reason or place we moved it to before we lock the thread. Its a pain to unlock it to fix. Sorry we confused you.
