7 members (wilbur53, Rusty Rod, D B Cooper, RaNfLaS, Gdads51, KEVINSKI, 1 invisible),
114
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,060 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 47 | Anyone know of a user friendly site with wheel bearing specifications for special application? | | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | Try McMaster for starters. Search "bearings" http://www.mcmaster.com/ | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Also try Jackson's old time parts @ www.oldtimeparts.com or 1-888-399-7278 in Deluth Minnesota.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | McMaster-Carr is a great industrial supply house but you won't find any truck or car wheel bearings - only industrial/commercial applications like lawn mowers, etc. Anyway that's all I saw.
Professional Novice
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | ironhead68,
I have looked at a bazillion bearing books and have come to the conclusion the only way a bearing would be listed for a specific application (wheel bearing) would be to find it in the parts manual for the vehicle involved.
McMaster-Carr does carry some Timken tapered roller units, but again, they are listed only by cup and cone number...you have to know what you want. With Timken units, you can mix cups and cones (bearings & races) to achieve different OD's, ID's and heights in your quest to make your own wheel bearings.
Unless someone else has done the research and fitting for a particular rig, without a specific bearing number, or size, finding a magic chart will be a real toughie. I wish one existed!
Stuart | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I agree Stuart; outside Chicago here, we have an industrial bearing supplier, Berry Bearing, that is part of the larger, Motion Industries group. I was going to save myself a bunch of money and buy all my bearings and seals from them. I've tried to get wheel, center support, rear axel bearings and seals by using the number on the bearings/seals and numbers from the parts books and they end up having to get them from the after market suppliers just like me. The counter man even told me, that I would be better off just ordering them from one of the vendors that sell restoration parts because when they get them, they have to mark them up. I found that to be true in almost all cases. I just ordered inner/outer rear hub bearings and seals for my 3/4 ton from Carter, they had the best prices, but only three out of the four bearings. I've been waiting on the B/O for a week now and they say might be ten days, then it will probably be another ten days till they ship them, Carter has been very slow getting an order out in the past. Oh, and McMaster is only an industrial supplier, I also doubt they would have any thing auto related. That said, I did find 1/4”x .028” Bundyweld plated steel brake tubing there for $15 for a 21ft. coil after I just paid $25 for a 20ft. coil at Inline Tube. Ten bucks differance almost buys another coil of tubing. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Oct 2006 Posts: 289 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 289 | All the players have online catalogs listing millions of bearing sizes and I'm sure they have stuff not on their public web's. Search for Timken Bearings, SKF Bearings, NTN, MBS and FAG. (A German bearing mfg) Then go to there on line catalogs. | | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | 57_ That timken link did not work for me.
Professional Novice
| | | | | Joined: Oct 2006 Posts: 289 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 289 | Try this http://www.timken.com/industries/automotive/ then selectect aftermartket in the blue, and a box will pop up, then select automotive. A new page pops up, select application catalog. After you fill in the boxes, you can select the top menu to see more info. | | |
