2 members (NJC, Otto Skorzeny), 67 guests, and 4 robots.
Topics128,263
Posts1,058,134
Members48,482
#226341 02/03/2007 7:00 PM
I
I Offline
Anyone know of a user friendly site with wheel bearing specifications for special application?
#226342 02/04/2007 4:09 PM
Try McMaster for starters. Search "bearings"
http://www.mcmaster.com/
#226343 02/05/2007 1:14 AM
Also try Jackson's old time parts @ www.oldtimeparts.com or
1-888-399-7278 in Deluth Minnesota.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#226344 02/05/2007 3:17 PM
McMaster-Carr is a great industrial supply house but you won't find any truck or car wheel bearings - only industrial/commercial applications like lawn mowers, etc. Anyway that's all I saw.
Professional Novice
#226345 02/05/2007 4:03 PM
ironhead68,
I have looked at a bazillion bearing books and have come to the conclusion the only way a bearing would be listed for a specific application (wheel bearing) would be to find it in the parts manual for the vehicle involved.
McMaster-Carr does carry some Timken tapered roller units, but again, they are listed only by cup and cone number...you have to know what you want. With Timken units, you can mix cups and cones (bearings & races) to achieve different OD's, ID's and heights in your quest to make your own wheel bearings.
Unless someone else has done the research and fitting for a particular rig, without a specific bearing number, or size, finding a magic chart will be a real toughie. I wish one existed!
Stuart
#226346 02/06/2007 3:39 PM
I agree Stuart; outside Chicago here, we have an industrial bearing supplier, Berry Bearing, that is part of the larger, Motion Industries group. I was going to save myself a bunch of money and buy all my bearings and seals from them. I've tried to get wheel, center support, rear axel bearings and seals by using the number on the bearings/seals and numbers from the parts books and they end up having to get them from the after market suppliers just like me. The counter man even told me, that I would be better off just ordering them from one of the vendors that sell restoration parts because when they get them, they have to mark them up. I found that to be true in almost all cases.
I just ordered inner/outer rear hub bearings and seals for my 3/4 ton from Carter, they had the best prices, but only three out of the four bearings. I've been waiting on the B/O for a week now and they say might be ten days, then it will probably be another ten days till they ship them, Carter has been very slow getting an order out in the past.
Oh, and McMaster is only an industrial supplier, I also doubt they would have any thing auto related. That said, I did find 1/4”x .028” Bundyweld plated steel brake tubing there for $15 for a 21ft. coil after I just paid $25 for a 20ft. coil at Inline Tube. Ten bucks differance almost buys another coil of tubing.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
#226347 02/07/2007 5:39 AM
You can go to Timken and search their catalog by vehicle or bearing number.
http://www.timken.com/industries/automotive/autoaftermarket/timkencatalog/PartCatalog.
I spent hours trying to find tapered rollers for my '57 and avoid paying over 100.00 for a set. I figured it all out, and found a website for a firm in Japan that makes the inner (outer is 70's camaro) but I couldn't find a retail outlet, except a guy in Georgia that wants as much as the resto shops.
I think the AD and TF 1/2 tons use the same front wheel bearings. I ended up buying a set from CPP during their December Ebay sale. White Box with no ID or numbers on the bearings. If you want std ball bearings, try FLAPs or Napa. Outer is a B01 and I forget what the inner is. I'll try to paste my TF bearing links: BCA is some sort of industry standard designation. TF use a BCA# B01
http://forums.corvetteforum.com/showthread.php?t=1177441 (see c1 bearing source)
http://www.mbs-m.co.jp/page026.html
http://www.mbs-m.co.jp/page039.html
http://www.ntnamerica.com/NTN-BCA_Wheel_Bearing.htm
All the big players in bearings make BCA bearings. MBS are the only guys I found making the inner in a tapered roller.
Good Luck
Eric
http://s1199.photobucket.com/user/sparky234/library/My%2057%20Chevy%20Stepside?sort=3&page=1
'57 Chevy 3100 (Little Red)
'81 RD350 LC - Fun, Fun, Fun
'83 GS1100E - Pocket Rocket
#226348 02/07/2007 5:45 AM
All the players have online catalogs listing millions of bearing sizes and I'm sure they have stuff not on their public web's. Search for Timken Bearings, SKF Bearings, NTN, MBS and FAG. (A German bearing mfg) Then go to there on line catalogs.
Eric
#226349 02/07/2007 4:04 PM
57_
That timken link did not work for me.
Professional Novice
#226350 02/08/2007 1:36 AM
Try this
then selectect aftermartket in the blue, and a box will pop up, then select automotive. A new page pops up, select application catalog. After you fill in the boxes, you can select the top menu to see more info.
Eric
