6 members (SNOYL, Jon G, Bill Hanlon, Robert Crandall, oldsteve, Otto Skorzeny), 79 guests, and 4 robots.
Topics128,180
Posts1,057,153
Members48,464
Junior Member
Junior Member
Went down to Waterhouse Motors recently to get the inspection results on my GMC 302. The cylinder bores will be clear at 0.030" over and both the mains and rod-ends at 0.010" under. The thrust wear on the crank at the #3 main that I was so worried about was actually cheap to fix ($57.00). They are holding everything while I gather parts. They had a set of NOS rod bearing at a real good price and I've located main and cam bearings, 0.040" over pistons and exhaust valves. Once I got the pistons I checked back with them and damned if they didn’t have three sets of NOS +0.040" rings grin . So if anyone else needs GMC 302 +0.040 rings call them. Just got the intake valves today.
All the parts buying has left my truck fund very lean, so will have to wait a while to start putting things together.
Where did you locate pistons? I need a set of .030 over. I have been shopping around. Got any good leads you can pass my way? Are your pistons stock or hop up parts?
52 GMC Suburban...52 Chevy 3/4 ton...49 CHevy 1/2 ton Rod...49 GMC 1/2 ton retro rod project
