4 members (lumbersawyer, Hush, 2 invisible),
64
Mod | | | Forums66 Topics128,026 Posts1,055,407 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | What's the differance between water pumps from the 235 to 261? Are they interchangeable? Does anybody know a casting number or a place to get a new or rebuilt pump for a 261? | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | The pump on the left came off my '54 235 ('53 car w/PG, actually) and the one on the right (with shortened shaft) is what I put on my '61 261. I don't know about the newer 235's. Water Pumps 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The "official" 261 water pump has dual tapped holes for heater hoses, one goes to the actual heater and one goes to the bypass port on the thermostat housing. Other than that the 235 water pump from the same year will fit and work, you just won't have a place to put that hose. There was a water pump change in '55 from the 216 style with the plate to the late style with the impeller in the block.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | I looked at my parts truck with the original pump on it this morning. It has only one threaded hole on the pump and the return hose goes directly to the water neck. So if I understand any 235 pump for 1954 should work on my 261 being as I only have the one hole right now? | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Helpful photos. I have both on two different 235s. The pump with two holes and a flush fit was on my 53 and the other with the big impeller is on my 1956 era 235. Unless its not a 235 which I have questioned. | | | | | Joined: Feb 2005 Posts: 199 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 199 | I looked at two of the pumps I have and got the casting numbers.
1. 235 casting number 3774186 no bypass hose outlet.
2. 261 casting number 3757282 with bypass hose.
I think both to be original.
Hobert
"The Lord is my shepherd"
