1 members (parklane410),
73
0
Mod | | | Forums66 Topics128,080 Posts1,055,951 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | I'm having my mechanical temp gauge rebuilt for my '54 GMC with a Chevy 235 engine. Does anyone know how long the capillary tube is supposed to be from gauge to block?
TIA. | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | The capillary tube on my 1954 (235) Chevy truck temperature gauge is 52" from back surface of the gauge cluster to tip of temperature probe. Hope this helps.
Dave | | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | Fla54-
That helps a LOT. Thanks very much. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | tlorber, where ya havin' that done at??? Denny G
Denny G Sandwich, IL
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Denny, you didn't ask me but D&M Restorations in Greenville S.C. is pretty dang good. Mike did guages for me several years ago and they are working fine. I have sent a lot of folks over there in the past and just this past Friday and took him a guage to repair out of a 57 chev car. He does good work and very reputable. 864-421-9959 and ask for Mike or Diane and tell them Alvin said to call.....and to give you a discount!!! | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Thanks Alvin, I've heard you mention them before but didn't know if they were local or would take guages Thru the mail. I'll print out their number and give them a call when I get the gauge out. Right now I'm trying to get a carb on her that dosn't leak fuel out of every joint. Denny Graham Sandwich, IL
