Brrrr
place holder
3 members (Hotrod Lincoln, Bill Hanlon, Rich'sToys), 114 guests, and 1 robot.
Topics128,274
Posts1,058,430
Members48,489
Someone posted that His tank sounds like it has gravel in it moving around...When I removed My tank
it sounded laike a rock rollong back and forth as I tilted it....I set it aside to get back on the cab
til later...Well, when I am not working on the truck
before bedtime I read on the gas tank that the manufacturer put like a large ball-bearing in the tank for some reason which I have forgotten about..
It was either in the repair manuel, or it was in
the Pickup N Panels magazine, and also the tame of the stovebolt club I was in, then bellied up...
So anyway I left the ball-bearing in the tank yet....Anybody else know of this ??? Bill B
1952 Chevy 3104 Shortbed 5-window
Remember; Politicians and diapers both need to be changed
often, and for the same reason.....
urban legend, if you have a bearing loose in there, someone dropped it in, or some gravel - most likely you have an old sender float, or part of it, or a baffle broken loose
I will make a good effort to find the article
that addresses the mystery...Bill B
Ex Hall Monitor
Ex Hall Monitor
I can't help. All my tank had in it was rust and varnish. grin grin ohwell
Rattling bearings or rocks in the gas tank can help remove rust. Maybe someone left one in.
I hate when the bearings go out in the tank... They are such a pain in the @ss to replace! grin
Ive never heard of that before but it would make an interesting read.
My 1953 Chevrolet
1947.1 Gallery
