| | | Forums66 Topics128,274 Posts1,058,431 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 339 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 339 | Someone posted that His tank sounds like it has gravel in it moving around...When I removed My tank it sounded laike a rock rollong back and forth as I tilted it....I set it aside to get back on the cab til later...Well, when I am not working on the truck before bedtime I read on the gas tank that the manufacturer put like a large ball-bearing in the tank for some reason which I have forgotten about.. It was either in the repair manuel, or it was in the Pickup N Panels magazine, and also the tame of the stovebolt club I was in, then bellied up... So anyway I left the ball-bearing in the tank yet....Anybody else know of this ??? Bill B | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | urban legend, if you have a bearing loose in there, someone dropped it in, or some gravel - most likely you have an old sender float, or part of it, or a baffle broken loose
Bill | | | | | Joined: Oct 2006 Posts: 339 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 339 | I will make a good effort to find the article that addresses the mystery...Bill B | | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 |
| | | | | Joined: May 2001 Posts: 1,908 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,908 | Rattling bearings or rocks in the gas tank can help remove rust. Maybe someone left one in. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | I hate when the bearings go out in the tank... They are such a pain in the @ss to replace! Ive never heard of that before but it would make an interesting read. | | |
