1 members (1 invisible), 78 guests, and 2 robots.
Topics128,034
Posts1,055,546
Members48,425
#226036 01/29/2007 7:45 PM
Apprentice
Apprentice
Okay, so yesterday/last night I was *hoping* to finish the T5 install in the truck, but ran into trouble.
When I started, I had the T5 bolted up to a stock '57 Chevy V8 passenger car bellhousing, with a stock '57 flywheel, stock pressure plate. Everything bolted up no problem.
I needed to install the clutch disc and input bearing, so I yanked the tranny and pressure plate out, installed the bearing and clutch assembly.
When I went to bolt the tranny back up, I could barely get the tranny in, and I've got the bolts in and the tranny is still a 1/4 to 1/8 away from the bellhousing.
I remember reading somewhere that the 235 sixers need to shim the tranny, I don't know if I have a similar situation with my combo of parts.
Thanks guys. I'll be tearing it all apart again tonight. I realize its either the clutch disc or throwout bearing. Any help or insight would be appreciated!!
Scott
http://waywardgarage.com
1957 Chevy 3100
#226037 01/29/2007 7:47 PM
Apprentice
Apprentice
I'm sorry, I said above its either the clutch disc or throwout bearing, I should have said clutch disc and pilot bearing. Sorry!
Scott
1957 Chevy 3100
#226038 01/29/2007 8:22 PM
rabidscott, I have not done a T5 swap...yet but from what I read is it possible that the pilot bearing is to long and not letting the pilot shaft go all the way in?? I think there was a thread about this in the engine driveline forum but I am not sure. I am interested in what it is as I may do this somewhere in the near future.
#226039 01/30/2007 6:52 PM
Junior Member
Junior Member
I feel for ya....recently went through the same thing.
Here is part of my story
here
Right now, I have 1/8" washer in place as spacers and a mechanic at work is machining a permanent spacer for me.
Also check the flywheel bolt heads...you may be hitting on them...?
#226040 01/30/2007 8:20 PM
DW Offline
two things to check
1)make sure the pilot/clutch bearing is driven all the way in (that was my problem)
2)make sure the clutch is front side forward.
good luck
dave
#226041 01/30/2007 9:59 PM
I've read where guys have both shortened the shaft and/or ground the splines farther back to allow the clutch disc enoungh room. It seems to me that a spacer would solve both problems and allow you to use stock T5 parts if it ever needs a rebuild.
#226042 01/30/2007 10:05 PM
Baldy -
Your comments are some of the best I have read. Short, concise and to the point. I think you are "right on" and your "spacer" comment solves most ALL of these type of basic problems on AD trucks.
Joe smile
#226043 01/30/2007 11:16 PM
Riding in the Passing Lane
You need to grind the grooves in the trans shaft longer. Put the disc on the shaft & mark where it stops. Grind the grooves with a die grinder or Dremel tool til in goes in about a 1/4- 1/2 in. further. I take it you have cut the front of the shaft & the coller to match the old trans. Co-pilot?
1972 Chevy c10 Cheyenne Super
#226044 01/31/2007 8:49 PM
Apprentice
Apprentice
Okay guys, I got the tranny out last night.
Anywho, the end of the input bearing retainer was all chewed up from me forcing the tranny into the clutch disc. I took what I assumed was 3/16 off the end of the input bearing retainer, and picked up washers, 1/2" stack for each tranny to bellhousing bolt. This should work, at least temporarily, correct?
I also talked with a couple of my friends about making a machined aluminum adaptor, if this is the correct spacing, etc.
I will be trying to put this together again tonight. Maybe I'll be able to go around the block!!
Scott
1957 Chevy 3100
