Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (50Chevy3100, Shade Baby, 2-Ton), 104 guests, and 4 robots.
Topics128,277
Posts1,058,456
Members48,490
#225855 01/28/2007 12:27 AM
Well, I need to hear from you folks that have behind the seat tanks. I'm to the point that I need to make a decision about whether to relocate the tank to under the bed, or get a new original tank for my 56 TF. Frankly, I'm not all that keen to relocate. I did so on Sparky only because I couldn't get a new manufactured tank for a 42, but such is not the case with the Task Force models. My real question is if I install a new stock tank and hoses, etc., am I still going to have gasoline odors in my cab? This truck will be my everyday driver, and I really don't want to smell gas. By the same token, I don't want to give up my stock instrument cluster and go to the expense of custom guages if I go to the Mustang tank. Opinions? Your experiences?
#225856 01/28/2007 12:41 AM
I've never had any gas odor with the in-cab tank in any truck I've had - just hafata make sure everything is right, like the sender gasket, the fuel line, and the rubber hose on the filler - the 2 TF trucks I have now have original tanks, and they work fine
#225857 01/28/2007 12:55 AM
I'll ditto that, make sure the rubber grommet around the filler is tight.
Larry
I don't own a vehicle that isn't old enough to drink.
#225858 01/28/2007 1:13 AM
I have driven trucks with the tank behind the seat for 40 years. The only times I've had fumes in the cab was due to old hoses. I've never even had an in-cab tank leak.
Fred
52 3600
69 C-10
#225859 01/28/2007 1:34 AM
The only fumes you'll have is from that old wipe rag you forgot was in your hip pocket!
#225860 01/28/2007 2:23 AM
I do get some fumes, generally on a very hot day with a full tank. Thought that was normal but maybe I should recheck my hoses. the sender gasket is good. However I would not relocate the tank.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#225861 01/28/2007 2:33 AM
Some people claim it's safer to relocate also. I disagree, if I get hit hard enough in the cab to explode my fuel tank, I wouldn't be alive to feel the fire any way,
Scott
And, olblu, make sure you have a vented gas cap too.
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#225862 01/28/2007 2:35 AM
I don't have any gas smell in my cab unless I happen to spill gas when i'm filling it up.
A tank that is properly installed and not leaking shouldn't stink up the cab at all.
Nothin' finer than puttin' down the road in an old truck, arm out the window, and a big ole cigar hanging out of your mouth.
You may also want to check to see if those vapors you're getting in the cab are not from the engine compartment instead of the fuel tank.
The '52 Dodge I have is horrible for that.
#225863 01/28/2007 3:17 AM
My '55 TF leaked at the bottom seam, not much but enough to smell. I sealed the tank (kind of a time consuming process) but the cab smells great. I didn't like the repro tanks that I looked at. If you take the time and examine closely you can find where the vapors are coming from.
Kim
#225864 01/28/2007 4:15 AM
I would recommend keeping it in the cab.
I too think it is the safer place.
Never had any problems with the one in my 52.
•1952 Chevrolet 3800 pickup
---All pictures---
#225865 01/28/2007 5:57 AM
I don't get any hint of gas smell in My 52..
As far as relocating the tank, it would be My opinion that the source of the oder could be fixed
alot cheaper than a new tank between the frame rails...In the Army when You drove a jeep You were
practically sitting on the tank...It was under the
seat...Bill B
1952 Chevy 3104 Shortbed 5-window
Remember; Politicians and diapers both need to be changed
often, and for the same reason.....
#225866 01/28/2007 6:32 AM
No smell in my 1951,I like it right where it is.If you are getting fumes,check your filler hoses.
1951 3100 Chevrolet
#225867 01/28/2007 7:21 AM
No gas smell in my 58 unless some gas is spilt. I agree with the others that it is safe to have the tank in the cab. It's mounted inside the frame rails, and there aren't many vehicles that would strike the side of the cab above the frame rails with their own frame. If I were starting from scrach, I might mount it under the bed, but I sure wouldn't go to extra expense to do it.
58 Fleetside, 235, "The Old Buckin' Bronco"
#225868 01/28/2007 10:07 PM
I agree with keeping the tank in the cab...Ya gotta remember the old trucks are built with steel..the factories had to relocate the tanks to the frame when they started building them with recycled beer cans...
Geoff
Geoff
68 GMC 3800
56 JD420C w/JD90 Loader
#225869 01/29/2007 2:08 AM
Z
Z Offline
the only problem i have with my inside tank{besides the rust}is if i fill it up it will overflow down the side of the truck on hot days.thats why i never put in more that twelve gallons.
#225870 01/29/2007 2:19 AM
As far as safety is concerned, if anybody hits you hard enough to rupture the fuel tank in the cab, you aren't going to be alive to enjoy the bonfire anyway.
#225871 01/29/2007 2:37 AM
Thanks guys. I think I'm going to leave the tank in the cab. It should fit fine behind the 95 Suburban Seats and console. I think I'll fabricate a panel to hide it with upholstery though. Should be an easy fix. Previous owner had the original tank braised, but said he did not think it would hold for long - that I could glass over it with the epoxy tank repair kit. I can hear rust or something inside when I turn it over. That is why I'm thinking of just ordering a new repro tank and avoiding the hassles. Any recommendations?
#225872 01/29/2007 2:40 PM
Junior Member
Junior Member
A new tank is better then repairing old stuff. With all new parts, you won't have any smells. Also, rust particals may screw up your fuel pump.
Just get a bigger hammer!!!
#225873 01/30/2007 12:19 AM
I had a leak in the tank of my first 1966 pick-up. The leak was easy to detect, and removing the tank to repair it was easy. I tend to agree that the tank in the cab is pretty safe. There is a lot of sheet metal protecting it.
#225874 01/30/2007 2:53 AM
as far as fumes in the cab my 64 has all orignal hoses and tank an i dont smell any fumes
LEWIS
#225875 01/30/2007 5:04 AM
Smell gas? Got a leak? The quickest way to find the leak is to use those strike anywhere matches.
~Jim
#225876 01/30/2007 9:50 PM
My '59 smells quite a bit when filled (&overfilled) but while 'wheeling last summer the gauge broke , it shows full at all times the ignition is on.Might be wiring, maybe a stuck float arm?? I don't know if it is the original tank, i doubt it- its too shiny. However my question is what is the capacity of the original (or repro) behind the seat tank??
any response is welcomed
jeff
220 - 221 whatever it takes
#225877 01/30/2007 11:27 PM
I agree with everybody just keep it in the cab...I just replaced my fuel tank on my 51..along with sending unit, and hoses...seems to be fine..
1951 3100
http://community.webshots.com/user/HolcombRacing11
"Every child is an artist. The problem is how to remain an artist once he grows up."
Pablo Picasso
#225878 01/31/2007 2:06 AM
Jeff, the TF tank is about 17 gallons - your problem may be a bad sender or bad gauge
#225879 01/31/2007 3:53 AM
I agree probably bad guage or sending unit..
1951 3100
Pablo Picasso
#225880 01/31/2007 6:14 AM
My specs. sheet on a 52 says 16 gal. Bill B
#225881 01/31/2007 7:24 AM
1 Offline
if your concered about the location of the tank buy a panel! being 6'6" tall fitting into the ad cabs won't happen for me unless i relocate the tank like the one i had years ago. guess i'm gonna be content with my panel. mmmm!
#225882 01/31/2007 5:47 PM
Thanks a lot. I've got to get out there and check the wiring from tank to gauge first, because if im right if the wire is shorted to ground(neg.) it would show full too. I was rockin and rollin when it happened.
#225883 01/31/2007 11:38 PM
That's how I remember it, a short to ground will show full. Seems like the most likely scenario for it always reading full, and replacing the wiring from the sending unit to the gauge is a cheap repair.
