3 members (klhansen, Otto Skorzeny, pdlightning), 36 guests, and 5 robots.
Topics128,023
Posts1,055,373
Members48,420
#225806 01/27/2007 1:04 AM
Apprentice
Apprentice
I removed the wood bed on my a 49 1/2 ton short bed. The cob nobber that had it before me had
10 to 15 bolts in each board plus the strips. total of 156 bolts that I had to grind, bend. curse, and more to remove them. Anyway the three cross support rails were just laying in the frame. Are they suppose to be welded in?
Marcus
#225807 01/27/2007 1:17 AM
the cross sills are not welded anyplace - the bolts in the skid strips hold the wood to the cross sills, special bolts thru the wood and the sills go to the frame - the bolts at the sides attach the sills to the bed via the angle strips
#225808 01/27/2007 1:34 AM
Apprentice
Apprentice
Thanks for the imformation. There is so many bolt holes in the cross members that it looks like swiss cheese?
#225809 01/27/2007 3:10 AM
yeah, some peoples kids eh? you might hafta look at welding up some holes if they overlap the correct ones, but if you have the right width boards , you can just use the right holes and ignore the rest ... there's lots of good info at Mar-K in PDF form about dimensions and how it all goes together
