| | | Forums66 Topics128,024 Posts1,055,392 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 49 Apprentice | | Apprentice Joined: Mar 2005 Posts: 49 | I removed the wood bed on my a 49 1/2 ton short bed. The cob nobber that had it before me had 10 to 15 bolts in each board plus the strips. total of 156 bolts that I had to grind, bend. curse, and more to remove them. Anyway the three cross support rails were just laying in the frame. Are they suppose to be welded in?
Marcus | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the cross sills are not welded anyplace - the bolts in the skid strips hold the wood to the cross sills, special bolts thru the wood and the sills go to the frame - the bolts at the sides attach the sills to the bed via the angle strips
Bill | | | | | Joined: Mar 2005 Posts: 49 Apprentice | | Apprentice Joined: Mar 2005 Posts: 49 | Thanks for the imformation. There is so many bolt holes in the cross members that it looks like swiss cheese? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yeah, some peoples kids eh? you might hafta look at welding up some holes if they overlap the correct ones, but if you have the right width boards , you can just use the right holes and ignore the rest ... there's lots of good info at Mar-K in PDF form about dimensions and how it all goes together Bill | | |
