| | | Forums66 Topics128,274 Posts1,058,432 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#22574 12/22/2003 3:50 PM | Joined: Jan 2003 Posts: 65 Member | | Member Joined: Jan 2003 Posts: 65 | Just a tip I thought I'd relay. To facilitate oil through the galley before starting up a dry engine, without sawing the handle off a nice screwdriver. Cut a lenght of brake line 1/4" OD, crimp one end, insert in drill and set crimp into oil pump slot. viola! | | |
#22575 12/25/2003 2:31 PM | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | 1/4 inch wood bit works well also. just make sure it's clean | | |
