2 members (homer52, Tronman),
239
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i just purchased a set of buick lesabre seats with side inpact air bags and i need to know if i have to deactivate them before i install them into my 54 truck? if i do how can it be done safely? ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | They should not deploy unless they are set off by the sensor in the front end(header panel area)and you are going over 20 MPH verified by the VSS(vehicle speed sensor).Are you sure you want those seats in your AD ?
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | I'd get 'em removed just in case.
In theory, they shouldn't deploy without being told to do so by a host of other systems, but i'm not sure i'd want to be sitting with a can of compressed gas under me.
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | yes i like the fact that they have intergrated seat belts. also i assumed since i didn't have the sensor they would not deploy. ron
| | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | i was married to a side impact air bag once... | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | avette4me, i wish mine had been more of an air bag and maybe i would have known what was going on in her head before she left after 36 years of marriage. ron
| | | | | Joined: Oct 2006 Posts: 122 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 122 | Without the wiring in place, including the connection to the SDM [Sensing Diagnostic Module] it should not be possible to deploy the airbag.
Do keep in mind though that with integrated seatbelts to the seats that you will be concentrating a very large load on the seat anchors. On new production vehicles, this results in added structure in the floor pan and is part of the reason a majority of vehicles have the seat belt anchors separate from the seat.
Hate to be in a frontal crash and have one of those seats come loose with someone in it who is strapped in and contacts a metal dash.... | | | | | Joined: Mar 2006 Posts: 11 Junior Member | | Junior Member Joined: Mar 2006 Posts: 11 | Your seat belts probly wont work in a collision if they are the kind with the electric solinoid on them. They are operated by the SRS module and are useless without it. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | can somebody respond to ray-mans comments about the solinoid? ron
| | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | I'm sure you got my P.M. ron, but just to let ray-man know the belts work just fine. The slightest tug locks them. Some of the time I can't reach the radio because the belts locked. There is not a solenoid or even a wire to activate them.
Bill | | | | | Joined: Oct 2004 Posts: 128 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 128 | The airbags are a pyrotechnic device and require current to deploy. No current source, no deployment. I'm not familiar with the GM connectors, but my guess would be they are of the self-shorting type. Which means, when they are disconnected from the vehicle harness, the leads are shorted together. This eliminates the possibility of a seperate power and ground path, making you safe from accidental deployment caused by a static charge.
John | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | WILBUR, GOT YOUR PM and i appreciate you taking the time to respond. i just downloaded the pictures of the seats in your truck to my pictures. a great referance. i hope my truck looks as good as your when i get done. i am not doing the work myself, don't have the skills or patience. just got the seats home today and have to clean them up. i thought they were a darker color than what they delivered but they have the right stock #. yes i pulled on the shoulder belt and it locks so everything is ok. my mechanic was concerend that the airbags might go off but with out power and the sensor it should not do that. i still will check at the local buick dealer, have friends that work there. thanks again. ron
| | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Those air bag initiators are worth some LARGE dollars! I know of cars being totalled out over the cost of replacing air bags after a wreck. There's absolutely no sense driving around with the equivalent of money forming the padding of your new seats. Have somebody remove the bags, sell them, and use some of the cash to get the seats reupholstered without them, then party with the rest. It's like free money! Jerry
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Free money.....I like the sound of that.
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | hot rod lincoln, what kind of money are you talking about? i had thought of that when it comes to steering wheel bags being stolen. hondas were a big target a few years ago. ron
| | | | | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | Before selling any SRS (supplemental restraint system) parts like air bag modules, check with local law enforcement. In some states it is illegal to sell used air bag modules. 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | |
