7 members (RoadsScholar, frogfarmer, klhansen, Otto Skorzeny, UtahYork, 1955 1 Series, greenie-reddy), 150 guests, and 1 robot.
Topics128,087
Posts1,055,974
Members48,430
#225351 01/22/2007 4:14 PM
Junior Member
Junior Member
Hi all,
I know there are kits out there to fit a 1984 Toyota power steering box in the original location for early Ford (48-56?) and for 55-59 Chevies.
My question is, can this p/s setup be used on '47-'55 Advance Design trucks? Does anyone make a kit?
Any input would be greatly appreciated.
52 Chebby
#225352 01/22/2007 7:44 PM
I don't know about Toyota steering boxes but here is a link to a page of Classic Performance tech articles with at least 3 about power steering on your model truck. Good luck!
wink
Professional Novice
#225353 01/23/2007 3:04 AM
Here's some ideas if you are up to the fab work and a little engineering.
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=6;t=001295
The info you will want is to the end of the postings
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
#225354 01/24/2007 5:09 PM
52,
Contact ABS in Orange, CA. www.abspowerbrake.com
714-771-6549. They do conversions on a variety of older vehicles. They also sell the components. I did the Toyota conversion on my 56 3100 about 5 years ago. It works great. It mounts inside the frame like the stock unit. You may have a clearance problem with your AD truck if you have a V-8 in it, depending on what exhaust system you have.
Fred
#225355 02/01/2007 8:26 PM
Back when I was looking around for PS boxes, I recall finding that the mid-70s Dodge truck PS boxes had both standard and reverse rotations, remanufactured by 'Lares.' If you fabbed up a bracket, the reverse-rotation box ought to fit inside the frame rail like the stock unit. You'd have to use a modern steering column, but big deal. I ended up using an 'ad-on' linkage system with sensor valve on the drag-link and a hydraulic ram behind the solid front axle. I still have the original steering column with 70s steering wheel.
#225356 02/03/2007 3:34 AM
You can use the original steering column.
many of the parts vendors, like Chevy duty, sell a bearing to install in the bottom of your old column after you remove the old box.
I did, and have pictures on the link below.
I used an IH Scout PS box, but I also swapped my front axle.
If nothing else, my pictures may give you some ideas.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
