7 members (TexasJim50, 1955 1 Series, Stovebolt48, 32Fordpuchoptop, lumbersawyer, JW51, 1 invisible),
54
0
Mod | | | Forums66 Topics128,080 Posts1,055,946 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 9 Junior Member | | Junior Member Joined: Nov 2006 Posts: 9 | Hi all,
I know there are kits out there to fit a 1984 Toyota power steering box in the original location for early Ford (48-56?) and for 55-59 Chevies.
My question is, can this p/s setup be used on '47-'55 Advance Design trucks? Does anyone make a kit?
Any input would be greatly appreciated.
52 Chebby | | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | I don't know about Toyota steering boxes but here is a link to a page of Classic Performance tech articles with at least 3 about power steering on your model truck. Good luck!
Professional Novice
| | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Here's some ideas if you are up to the fab work and a little engineering. http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=6;t=001295 The info you will want is to the end of the postings | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | 52, Contact ABS in Orange, CA. www.abspowerbrake.com 714-771-6549. They do conversions on a variety of older vehicles. They also sell the components. I did the Toyota conversion on my 56 3100 about 5 years ago. It works great. It mounts inside the frame like the stock unit. You may have a clearance problem with your AD truck if you have a V-8 in it, depending on what exhaust system you have. Fred
| | | | | Joined: Aug 2004 Posts: 141 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 141 | Back when I was looking around for PS boxes, I recall finding that the mid-70s Dodge truck PS boxes had both standard and reverse rotations, remanufactured by 'Lares.' If you fabbed up a bracket, the reverse-rotation box ought to fit inside the frame rail like the stock unit. You'd have to use a modern steering column, but big deal. I ended up using an 'ad-on' linkage system with sensor valve on the drag-link and a hydraulic ram behind the solid front axle. I still have the original steering column with 70s steering wheel. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | You can use the original steering column. many of the parts vendors, like Chevy duty, sell a bearing to install in the bottom of your old column after you remove the old box. I did, and have pictures on the link below. I used an IH Scout PS box, but I also swapped my front axle. If nothing else, my pictures may give you some ideas. Grigg | | |
