7 members (Goach2, Donf, Rusted Nut, Bill Hanlon, JW51, BC59, 1 invisible),
61
Mod | | | Forums66 Topics128,176 Posts1,057,122 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | Is the underseat gas tank from a 46 1 ton chevy truck the same as a 41-46 1/2 T PU underseat tank? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | | | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | For future reference, everything in the cab, including the cab and doors, is the same in '41 thru '46 Chevrolet trucks.
Only difference is the frame they sat 'em on, and the front fenders.
Even the hoods and grills are interchangeable.
The less expensive 1.5 and 2 ton trucks are a great place to score parts for the 1/2 ton trucks.
| | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | What fumblin said with one exception... the gas tank from a 1.5 or 2 ton has more capacity than the gas tank of a 1/2 ton, but should fit without much modification. | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Maybe the extra capacity thing was an option or something?
I've had 12 '39 thru '46 trucks out here, all 1.5 ton or 2 ton, and have yet to have a tank that wasn't a perfect fit in a 1/2 ton truck.
I don't know how they could make the tank any bigger, tho.. maybe slightly 'thicker'?
| | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | I just checked a 1942 Chevrolet Truck owners manual, it breaks the trucks into four catagories:
Light Delivery 3/4 ton Heavy Duty Schoolbus
It lists the tank size for the 1/2 ton trucks at 16 gallons, and the 3/4 ton and heavy duty truck tanks at 18 gallons.. with 'school bus' tank capacity at 20 gallons.
The two gallon difference, is so slight i'd never noticed it, and needed no modifications to put a 2 ton tank in a 1/2 ton.
| | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | I wasn't sure what the breakdown was, but I suspected a larger capacity to combat the lower fuel efficiency! I was making the point that the larger tank should be an ez upgrade because the cabs are the same! Thanks for the confirmation! | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 |
