8 members (Wally / Montana, Otto Skorzeny, TUTS 59, Jon G, JW51, 3800GUY, cmayna, 52GMC35424JD),
107
Mod | | | Forums66 Topics128,065 Posts1,055,865 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 101 Member | | Member Joined: Dec 2005 Posts: 101 | I have a 1976 Nova front clip on my 55. I am a having the hardest time finding drop spindles for it. I thought about installing V6 coil springs but I would rather replace the spindles. Can anyone help me out!
Roger http://www.flickr.com/photos/45469713@N00/?saved=1
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | | | | | | Joined: Dec 2002 Posts: 3,440 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,440 | put in 4 cylinder springs, and drop it to the ground!!
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Rusty Rod, The '76 Nova was a pretty big beast, are you sure it was available with a 4 cylinder. It sure would have been 'gut-free' if so. Stuart | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Try Global West I didn't find a web site for them I will keep looking. They have a set of ball joints that adapts their Impala dropped spindles to Nova/Camaro. Improves suspension geometry and uses the bigger brakes. | | | | | Joined: Dec 2005 Posts: 101 Member | | Member Joined: Dec 2005 Posts: 101 | Houston54 ,
Thanks for the link! These guys have what I need.
Roger
| | | | | Joined: Dec 2002 Posts: 3,440 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,440 | I've never seen or heard of a nova of that vintage having a 4 banger, BUT, if you go to the parts store, you can buy a set of springs for a Nova with a 4 cylinder...
| | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Nor I Rusty Rod. The early Chevy Two Novas used the Iron Duke witch used one SB Chevy head. Anyone who may know about this little motor please chime in, I am curious now. I think it was long gone by 76. I would also like to know what 4cld may have been used in 76. | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | I found this but I am sure that there was one that used a SB head anyone know?
The 151 (2.5L) inline 4 engine was used in '80-'83 CJs including the CJ-8, CJ-7, and CJ-5. The 151 is often called the "Iron Duke", but is actually a Pontiac engine designed to replace the Chevy "Iron Duke" I4 engine. The engine does have the Chevy bell housing bolt pattern though. The engine is manufactured by GM and uses a cast iron block and cylinder head with hydraulic lifters and 5 main bearings. The 151 cetainly is not a screamer, the AMC I4 has much better HP and torque ratings.
The neat part about the engine is it has the same bell housing bolt pattern as a Chevy small block. The bell housing makes a great low buck Ford/Jeep to Chevy adapter since it is basically Ford on the transmission side and Chevy on the engine side. A regular Chevy bell housing will bolt to the 151, so if you plan a transmission swap, a Chevy transmission would be the way to go. Also, a Chevy 305 or 350 will bolt right to the Iron duke bell housing. The down side of dropping in a V8 is most transmissions used with the Iron Duke are light weight units.
The GM 151 has the intake and exhaust manifolds on opposite sides of the cylinder head, but the AMC 150 has the intake and exhaust manifolds on the same side of the cylinder head. The picture at the top of the page is the passenger side with the intake manifold and carb. The drivers side is pictured below with the exhaust manifold removed.
GM 151 Bore x Stroke 4.00" x 3.00" Displacement 151 ci(2.5L) Compression Ratio 8.2:1 Horsepower (net) 82@4000 Torque (net) 125@2600 Main Bearings 5 Valve Configuration OHV Fuel Rochester staged 2bbl
Contributors Thanks to David Ewing for the manifold identification tip. Thanks to Ed Lowe for keeping my GM engine history straight. | | | | | Joined: Apr 2005 Posts: 187 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 187 | The Iron Duke was a 153 ci.,basically it was a 23 0 with two less cylinders. I have one out of a 62 nova,I thought about putting in a 3100.
_____________ Floyd If we choose being kind over being right,we will be right every time. Knowledge is a poor substitute for experience. Remember what is precious to another, may not be to you, but it is precious nonetheless. 1948 Chevy 2-Ton | | |
