7 members (48jim1ton, 2-Ton, JW51, Jman, 32Fordpuchoptop, Jay R, Peggy M),
92
Mod | | | Forums66 Topics128,042 Posts1,055,601 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 11 Junior Member | | Junior Member Joined: Aug 2006 Posts: 11 | Hi
I have a 1936 chev truck and I have recently cleaned up the fuel tank. Can somebody advise me. The steel plate in side is this a baffle? or has it dislodged it just floats and there is a cork ball inside is this to stop the tank from overfilling by floating to the filler hole when its full?
Cheers..Shane | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I've never seen the tank out of a 36. My 38 has a "U" shaped baffle in it to keep the gas from sloshing around & making the gas gauge dance. The sending unit is located inside the baffled area. The only cork I've seen is on the end of the sending unit arm. Someone else will have to help you with that one. Welcome to the 'bolt Shane.
