| | | Forums66 Topics128,049 Posts1,055,635 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 11 Junior Member | | Junior Member Joined: Aug 2006 Posts: 11 | Hi
I have a 1936 chev truck and I have recently cleaned up the fuel tank. Can somebody advise me. The steel palte in side is this a baffle? or has it dislodged it just floats and there is a cork ball inside is this to stop the tank form overfilling by floating to the filler hole when its full?
Cheers..Shane | | | | | Joined: Oct 2005 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 69 | There should be a baffle, there shouldn't be a cork ball. Do you have a float on your sending unit, maybe someone replaced a leaky float with a cork ball
New deal for old steel
| | | | | Joined: Aug 2006 Posts: 11 Junior Member | | Junior Member Joined: Aug 2006 Posts: 11 | Thanks for the info
I thought it was a baffle apparently the cork ball is an old idea over here often used in boats, when you fill the tank right up it stops overflow especially being under the seat.
Shane | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
