6 members (Peggy M, Otto Skorzeny, Rusty Heaps, DadsFirstPickup, Hotrod Lincoln, klhansen), 132 guests, and 0 robots.
Topics128,043
Posts1,055,609
#224905 01/18/2007 9:57 AM
Junior Member
Junior Member
Hi
I have a 1936 chev truck and I have recently cleaned up the fuel tank. Can somebody advise me. The steel palte in side is this a baffle? or has it dislodged it just floats and there is a cork ball inside is this to stop the tank form overfilling by floating to the filler hole when its full?
Cheers..Shane
#224906 01/19/2007 4:57 PM
There should be a baffle, there shouldn't be a cork ball. Do you have a float on your sending unit, maybe someone replaced a leaky float with a cork ball
New deal for old steel
#224907 01/19/2007 10:45 PM
Junior Member
Junior Member
Thanks for the info
I thought it was a baffle apparently the cork ball is an old idea over here often used in boats, when you fill the tank right up it stops overflow especially being under the seat.
Shane
#224908 01/20/2007 1:17 AM
Ex Hall Monitor
Ex Hall Monitor
