0 members (),
221
0
Mod | | | Forums66 Topics128,162 Posts1,056,940 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 222 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 222 | Well I took the gas tank out of my 51, 3600 this weekend. The truck had been setting in a field for years before I got it. I drained the most foul smelling gas out of it you could imagine, five gallons worth. Now one end of the tank, the end opposite of the filler, weights about 5 to 10 pounds more than the filler end. Any guesses as to what is in there weighing it down? It won't roll or shift around when I tilt the tank. Guesses?!! | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Dirt would be my guess.
Well.. nasty gas soaked dirt that's now some kind of mud paste kind of crap.
You may have to get the filler neck off the tank and peek in there with a stick and a flashlight to get a better idea of what it might be.
| | | | | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | Remove the gas tank sending unit and look thru there.I woud be buying a new tank. | | | | | Joined: Jul 2006 Posts: 187 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 187 | Hardened shellac. That gas has sat for a long time. Buy or retrofit a new tank or your carb and motor will be sorry. | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Could be whats left of the 8 pound bag of sugar somebody dumped in the tank the night before it quit running.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | What ever it is Rick I'd sure plan on spending $150 for a new tank. I have one that had rust in it and the PO said he flushed it out, "real good". Now about every week or so I have to pull the glass bowl and clean the screen. I'm sure it's just a matter of time before I start smelling gas in the cab. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Nov 2000 Posts: 700 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 700 | My 1941 in the Stovebolt Gallery My Photo AlbumBut I tried, didn't I? ... At least I did that. RP McMurphy The past belongs to the future...but only the present can preserve it. Besides the noble art of getting things done, there is a nobler art of leaving things undone. | | | | | Joined: Nov 2006 Posts: 180 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 180 | I know what you better not do....light a match to see whats in there....I definately wouldnt suggest that!
1950 Chevy 3100 5 window "in progress" 1967 Chevelle 300
| | | | | Joined: Nov 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 108 | | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | If your tank has baffles in it, looking in the sending unit hold may not tell you much. I'm in agreement that it's probably old gas that's turned into varnish. Normally I'd recommend cleaning it with acid & recoating the inside but if there's that much in the tank and if new tanks are available for your truck, buying a new tank is probably the best way to go. I didn't have an option with my 38, new tanks aren't available. If you're determined to keep the original tank, there is an outfit that splits the tank, cleans & repairs it, welds it back together then coats it. click
| | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Originally posted by Tiny: If you're determined to keep the original tank, there is an outfit that splits the tank, cleans & repairs it, welds it back together then coats it. click I love their slogan.. "A Great Place to take a Leak!"
| | | | | Joined: Feb 2006 Posts: 222 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 222 | Okay, you all win! I will get a new tank. Gotta go got to take a ___! | | |
