1 members (Tronman), 60 guests, and 2 robots.
Topics128,079
Posts1,056,310
Members48,442
#224692 01/16/2007 4:20 AM
I need some help with where I can purchase a vacuum line and also directions and pictures of where it would go for a 55 1st stock.
Curtis.
I can't help with where to hook it, but I get my vacuum line from the local auto parts store.
They have it in a roll at NAPA and will cut off as many feet as you need.. take a hunk of the old line with you so they can match it up.
Elmers55,
I think the line attaches to a fitting on the center plenum of the intake manifold, goes through the firewall and into a small nipple on the vacuum motor.
The proper connection on the vacuum motor will probably be a brass nipple. The vent tube is usually made of the same material as the motor body, and should be left open.
Stuart
I guess I need to clarify a little better.
This line would come from the wiper motor under the dash, through the firewall and then after that I need some help. When I got the truck it had no vacuum line for the wiper motor. So I need help in routing the line to and from and also what kind of line, because it looks like I would need a rubber line coming off the wiper motor and then a steel line to run to the carb and fuel pump, I believe.
Curtis.
Curtis,
Sounds like you are referring to a vacuum wiper motor that is connected to a dual-action fuel pump. Yes, that plumbing is a little more complicated than a standard set-up.
Try a search in all forums for "dual action" and "dual-action". You will find several discussion on how to make the connections.
Tim
Curtis,
Send me an Email, and I will send back a picture of the metal line to the wiper and how it is routed. Am rebuilding my double action at the moment, so it is easy to see the routing.
Richard
58 3104
Tim,
you are correct. I will do that. thanks for the info.
Curtis.
