2 members (walterhvogel, klhansen), 114 guests, and 2 robots.
Topics128,035
Posts1,055,559
#224455 01/14/2007 6:28 AM
I'd like to convert my 72 Chevy Shortbed Stepside to four wheel drive. Has anyone ever replaced the body of a later model truck (ie 80s or 90s) and replaced it with the 67-72 body? How much work is required as far as bracketry, etc. or will it bolt up? Thanks!!!!!
'57 Chevy 210 (235)
'54 Chevy 3800
'49 Pontiac Streamliner (239)
'46 Chevy 3/4-Ton (216) (Sold)
'46 Chevy 1 1/2-Ton (Sold)
'50 Chevy Loadmaster Semi (Sold)
'68 Chevy Stepside (Sold)
#224456 01/16/2007 4:50 AM
It surprizes me that noone has done this.. If I could find a cheap 67-72 short bed 4x4 chassis, I would go that route. But I can't find one for a decent price. Any suggestions? Anyone?
'57 Chevy 210 (235)
'54 Chevy 3800
#224457 01/16/2007 5:20 AM
There was a series in one of the four-wheel-drive magazines a couple years ago on what it takes to convert a two-wheel to four-wheel.
My neighbor used to have a '73 pickup sitting on a '72 four-by frame. I didn't see it built but was there to watch the body come off the frame. In that case most the brackets looked stock, but I don't know if they were moved from a '73 or if the body fit the '72 brackets.
The two-wheel front suspension was basically the same from '63 to '87, so you might find that a frame built before '88 an easier swap.
'88 is the first year for IFS on GM four-wheel-drive. I haven't been under a short-box that I remember, but I own a '89 long-box extended cab four-by and it has a very flat frame between about the fire wall and the rear spring mounts.
I'd think it could be done and might be real successful. But I've not seen it done.
#224458 01/18/2007 4:48 AM
Thanks for the response. I guess i'll have to go to a junk yard to take some measurements off of a 73-87 vintage frame. I would assume that the wheelbases are the same for these years. Thanks again.
'57 Chevy 210 (235)
'54 Chevy 3800
