3 members (rfs56trk, Wally / Montana, Gdads51), 93 guests, and 3 robots.
Topics128,065
Posts1,055,868
Members48,428
# from pad next to distibutor.......F224A
#'s from right side of head
B61 848
850
#'s from left side (top) of head
3836850
GM 5
any info will help..thanks
Carl
'58 3600 350/4-sp/stepside/big window cab
'59 3100 235/4-sp/stepside
looks like a head stamped 3836850 = 1958-1962 261 engine head from "the forgotten engine".
I'm sure someone will help you with the block casting number,it appears to be missing some numbers,i may be wrong ? There should be about seven digits before the F ? The numbers after your F don't look right. I would almost bet you have a 261 engine.
1951 3100 Chevrolet
The # from the distributor pad come up as a 235, Flint plant, built Feb. 24, '57-'61 passenger car application.
Bill Burmeister
Hey longbox55,where did you come up with the block casting identifcation ? I looked on inliners but had no luck . what is the head ? I came up with 261 head ,am i wrong ?
1951 3100 Chevrolet
Yes, that is a late 261 head. Put on a 235 it will lower the compression a tad.
Paint & Body Shop moderator
I went from the # that you gave from the pad behind the distributer. My information came from tha Catalog of Chevy Truck ID Numbers 1946-1972, which is published by Cars & Parts. This book has most all of the engine, trans, and differential numbers plus color codes and option numbers.
Bill Burmeister
