| | | Forums66 Topics128,049 Posts1,055,652 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 125 Member | | Member Joined: Oct 2006 Posts: 125 | # from pad next to distibutor.......F224A
#'s from right side of head B61 848 850
#'s from left side (top) of head 3836850 GM 5
any info will help..thanks Carl
'58 3600 350/4-sp/stepside/big window cab '59 3100 235/4-sp/stepside
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | looks like a head stamped 3836850 = 1958-1962 261 engine head from "the forgotten engine".
I'm sure someone will help you with the block casting number,it appears to be missing some numbers,i may be wrong ? There should be about seven digits before the F ? The numbers after your F don't look right. I would almost bet you have a 261 engine. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The # from the distributor pad come up as a 235, Flint plant, built Feb. 24, '57-'61 passenger car application.
Bill Burmeister | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Hey longbox55,where did you come up with the block casting identifcation ? I looked on inliners but had no luck . what is the head ? I came up with 261 head ,am i wrong ? 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Yes, that is a late 261 head. Put on a 235 it will lower the compression a tad.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I went from the # that you gave from the pad behind the distributer. My information came from tha Catalog of Chevy Truck ID Numbers 1946-1972, which is published by Cars & Parts. This book has most all of the engine, trans, and differential numbers plus color codes and option numbers.
