4 members (Rich'sToys, rfs56trk, Otto Skorzeny, Rnl364), 156 guests, and 3 robots.
Topics128,089
Posts1,056,437
Members48,443
I just removed my trans to replace it with another one and noticed the bolts holes at the top of the housing are different on both trans's.
One has the housing sort of round with a bolt hole at the very top. The other tran's housing is flat on top with two bolts about 6" to 8" apart.
The old one was suppose to be a TH350, and when I bough the new one I was suppose to be buying a TH350. Help me figure out what I have!
Roger
http://www.flickr.com/photos/45469713@N00/?saved=1
Youv'e got one with the Buick/Olds/Pontiac bolt pattern. The one with the rounded pattern and the hole at the top is the Chevy pattern.
There is also a third variant with a narrow pattern for use with the 60 degree v 6.
Bill Burmeister
And still anouther that has both Chevy 90 degree and the BOP patterns in one. I will see if I can find you some pictures of all four and com back and post them for you.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
Is one favored over the others by truck guys like ourselves.
Roger
The innard are more or less the same, only the bolt pattern is different. The Chevy pattern would be the most likely one to use for the trucks as most have the Chevy engine.
Bill Burmeister
user
R Online: Content
Roger,
The favored one is the one that bolts up correctly and has all the other dimensional features including spedo and mounts. One other variant is a 250 transmission - it looks like a 350 but has weaker internal components & was designed for lower HP engines, 6 cyl's, etc - early 80's Olds Cutlass comes to mind. Fred
There's also the 375, it was used in some Buick application as I recall. It has a longer tailshaft.
There's also a truck 375, basically a short tailshaft 400. It was use in 4x4 trucks with tha NP203 full time t-case. My parents used to have a '76 Blazer that was equipped with that trans/t-case combo (Dad special ordered it that way).
Bill Burmeister
