1 members (Phak1), 48 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#224028 01/10/2007 5:17 AM
Junior Member
Junior Member
Have a 1949 1/2 ton chev.Heater motor will not run.To pull it out do I have to take the core and all out?
Jim Geurts
#224029 01/10/2007 9:00 AM
i m not 100% but i dont be lieve so.Have you checked to see if you have power at both sides of the switch?Ron.
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are...
My progress pics
#224030 01/10/2007 3:17 PM
Junior Member
Junior Member
The switch was gone when I bought the truck.There are three wires that run from the motor.I ran the power to all and it did not run.Was wondering, is one the power wire and two of them for the switch? That would mean that two would have to be connected to run the fan?
Jim Geurts
#224031 01/10/2007 4:46 PM
check Deve's antique truck restorations, I think a link is here on the site, has a nice article with great pics on restoring AD heaters.
Mike
#224032 01/10/2007 9:07 PM
DW Offline
I pulled my 49 1/2 ton heater the other day due to excessive leaking. There apparently after several types of heaters, mine was bolted to the firewall with three studs/nuts. I just unhooked the two hoses, took off the three nuts, unhooked the heater wire at the switch and the two air ducts, and the whole unit came off. You can't get to (my) heater motor without doing this. It looks like the motor fits in the center of the round heater core and should pull right out after taking off a couple of screws, although I haven't separated it yet.
Dave
#224033 01/10/2007 10:06 PM
Junior Member
Junior Member
After I looked at the deve's site I see how it comes out.Now if I know how to wire it I might not have to pull it.
Jim Geurts
#224034 01/11/2007 12:51 AM
The core is held in the sheet metal housing with a couple of small screws. Once it is out there are 2 nuts on the flat part of the housing which holds the motor in place. You will have to remove the fan by loosening the set screw. Remove the fan but do note the direction it sits on the shaft. There is also a small sleeve on the shaft with a slot in it. That comes off with the fan blade. If you lose the shaft they are available at any electrical motor shop.
To wire mine I ran a ground to the metal housing and a wire through a fuse to a heater switch.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
