Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Woodcmiami, tclederman, Otto Skorzeny), 145 guests, and 3 robots.
Topics128,282
Posts1,058,496
Members48,490
#224012 01/10/2007 4:19 AM
I am wanting to put disc brakes on a 1964 C-10. I don't care about keeping it original. I also don't want to buy the new conversion after market kits if I don't have to. Does someone know what parts if any and off of what years will interchange. I am looking to buy a donor truck and don't really know what to look for. Thanks.
#224013 01/10/2007 4:24 AM
Welcome to the 'Bolt. You can swap the spindles from a '73-'87 C10 to you're '64 by swapping in the ball joints from the later trucks. It's a vritual bolt in. It will convert it to 5 lug on the front, so you might consider using the rear axle from the doner truck as well to keep the same pattern all around.
Bill Burmeister
#224014 01/10/2007 2:31 PM
Thanks for the info. That is exactly the answer I wanted because I have found a 1979 chevy I am buying already for the motor and transmission. I am also going to swith the power steering gear box. So after I switch the spindles and gear box what parts do I use for the rest of the steering(tie rods, etc.) I'm just not sure about the width difference in these trucks. Thanks.
#224015 01/11/2007 3:41 AM
Z
Z Offline
the later trucks 1.5"wider.use all the steering from the later truck.you will need a kit to mount the steering box.around 65 dollars.you will have to drill two holes for the later idler.just make a template from the donor truck to locate the holes.
#224016 01/11/2007 3:43 AM
Z
Z Offline
the later trucks 1.5"wider.use all the steering from the later truck.you will need a kit to mount the steering box.around 65 dollars.you will have to drill two holes for the later idler.just make a template from the donor truck to locate the holes.use the 79 power booster and master cylinder too,it will bolt to where the master cylinder was.
#224017 01/11/2007 4:49 AM
1 Offline
dose anybody know for a '46?
