| | | Forums66 Topics128,282 Posts1,058,496 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 19 New Guy | | New Guy Joined: Jan 2007 Posts: 19 | I am wanting to put disc brakes on a 1964 C-10. I don't care about keeping it original. I also don't want to buy the new conversion after market kits if I don't have to. Does someone know what parts if any and off of what years will interchange. I am looking to buy a donor truck and don't really know what to look for. Thanks. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Welcome to the 'Bolt. You can swap the spindles from a '73-'87 C10 to you're '64 by swapping in the ball joints from the later trucks. It's a vritual bolt in. It will convert it to 5 lug on the front, so you might consider using the rear axle from the doner truck as well to keep the same pattern all around.
Bill Burmeister | | | | | Joined: Jan 2007 Posts: 19 New Guy | | New Guy Joined: Jan 2007 Posts: 19 | Thanks for the info. That is exactly the answer I wanted because I have found a 1979 chevy I am buying already for the motor and transmission. I am also going to swith the power steering gear box. So after I switch the spindles and gear box what parts do I use for the rest of the steering(tie rods, etc.) I'm just not sure about the width difference in these trucks. Thanks. | | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | the later trucks 1.5"wider.use all the steering from the later truck.you will need a kit to mount the steering box.around 65 dollars.you will have to drill two holes for the later idler.just make a template from the donor truck to locate the holes. | | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | the later trucks 1.5"wider.use all the steering from the later truck.you will need a kit to mount the steering box.around 65 dollars.you will have to drill two holes for the later idler.just make a template from the donor truck to locate the holes.use the 79 power booster and master cylinder too,it will bolt to where the master cylinder was. | | | | | Joined: Jan 2006 Posts: 55 Member | | Member Joined: Jan 2006 Posts: 55 | dose anybody know for a '46? | | |
