| | | Forums66 Topics128,133 Posts1,056,398 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#22399 09/21/2003 7:55 PM | Joined: Jul 2003 Posts: 10 New Guy | | New Guy Joined: Jul 2003 Posts: 10 | 52 '3100' On the plug side of the engine there is a breather tube. How do you remove this tube so that I can get to the screw to remove the distributor? thanks for help, this is a great web site. | | |
#22400 09/21/2003 8:17 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | You should not have to remove the tube at all. - Make sure you have things marked (rotor position and distributor position), then remove the vacuum advance line. Once you have that done you can remove the hold-down bolt below and to the left of the distributor. You may need to wiggle the distributor some but it will come out. - When and if you need to remove the road draft tube, there is a screw located at the bottom edge of the block just above the oil-pan. Remove that screw and gently tap the top sides of the tubeback ad forth some to loosen it. It will then wiggle out. (It is a press in fit). To install the tube,use a little sealeraround the edge of the hole in the block and make sure you line up the lower part of the tube with the edge of the block. Use a small block of wood or a soft face hammer to tap the main part of the tube into the block just far enough to be snug and for the bolt hole to line up with the screw hole in the block.
#22401 09/21/2003 8:59 PM | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | Did the road draft tubes change after 49? Because mine is a press fit, no set screw. There is a screw into the block in that area, but it holds a baffle in place, and if you remove it, the baffle falls, and no way to set it back in place without removing the oil pan. | | |
#22402 09/22/2003 2:21 AM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The tube (at least on the 1/2 ton from '48-'62) is pressed into the block and the outlet "arm" originally had a strap around it that was bolted to the bottom of the block (as described by Mechainiac). This strap is often gone because it broke off easily after being bent a few times.
Engines on larger trucks might have had a PCV setup on the tube, with a line or two to the carburetor air-filter housing.
Tim | | |
