4 members (49nut, Steelonsteel, klhansen, Shardean), 73 guests, and 4 robots.
Topics128,022
Posts1,055,376
Members48,420
#222 08/10/2003 4:14 PM
any experience or opinions on using a corvette front and/or rear suspension on a 1950 pickup? I've been noticing the Flat Out Engineering ads.
#223 08/11/2003 5:53 PM
What's the application? If it's slow-n-low, there are better ways to go. If it's fast-n-furious, you're right to be so curious.
(Apologies for the rhyme, happens all the time.)
The IRS is a nice high performance setup, will give you better cornering but keep in mind the car it was designed for weighs about half of your Advance Design truck. Unless you're planning on racing, and have already made massive weight reductions, look into just lowering it or replacing with a higher geared straight axle.
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
#224 08/11/2003 6:25 PM
"but keep in mind the car it was designed for weighs about half of your Advance Design truck."
99 Vette curb weight ~3175lb
50 1/2 ton curb weight ~3250lb
Half?
#225 08/11/2003 7:59 PM
Hmm, guess not. So much for my ballpark figures!
-Boyo
#226 08/12/2003 5:48 PM
check out progressive automotive. www.progressiveautomotive.com
they have a front crossmember kit that accepts a front corvette suspension and can help you with the rear suspension.
