2 members (Otto Skorzeny, joe apple), 64 guests, and 4 robots.
Topics128,089
Posts1,056,139
Members48,435
#223798 01/08/2007 8:06 PM
I am trying to take the heater apart and the only thing left is the part with the heater motor and fan going through it. I removed the screw from the shaft, but the fan won't come off. Is there anything else holding the fan on the shaft, or is mine probably just rusty and stuck?
#223799 01/08/2007 8:40 PM
yes, just siezed on - try soaking with some spray and repeat tapping or prying every day for awhile, eventually it'll pop loose
#223800 01/08/2007 8:45 PM
Ex Hall Monitor
Ex Hall Monitor
It's a snug fit and sometimes there will be a little burr if someone overtightened the set screw. Most likely it's as Bill described. Be firm but gentle. grin
#223801 01/09/2007 12:14 AM
You might find a small sleeve on the shaft once the fan comes off. Try not to lose it but if you do a good electrical motor shop has boxes of them.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
