0 members (),
136
Mod | | | Forums66 Topics128,193 Posts1,057,259 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 48 Junior Member | | Junior Member Joined: Dec 2006 Posts: 48 | I saw some for sale and relized I dont have any on my truck!! I am not even sure where they go. Can you tell me how they work? I assume behind the tire. A picture would be great as well. [email protected]Thanks Jim | | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | They go up inside the fenders (over the tire) to help support the fender, I think.
I don't have any fenders in the back -- much less fender brackets -- but I do have some up in the front. | | | | | Joined: Dec 2006 Posts: 48 Junior Member | | Junior Member Joined: Dec 2006 Posts: 48 | I checked out you truck, old number seven. great looking truck.
I am thinking they go behind the wheel at the bottom of the flapping fender.
Funny, we are both guessing. Someone knows the truth.
Will the one that knows, please stand up? | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 |
dan-pa
| | | | | Joined: Dec 2006 Posts: 48 Junior Member | | Junior Member Joined: Dec 2006 Posts: 48 | I saw those originals on brads site. I can fabricate, no problem .....
Where do they go? Behind the tire? | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | The only rear fender braces I have on my truck are behind the wheel. They are only 3/8" round stock flattened on the ends with a hole drilled in each end. One end bolts to the bottom of the frame and the other bolts to the lower rear corner of the fender just behind the tire. They keep the fenders from flapen in the wind. These are very easy to make. Geroge | | | | | Joined: Dec 2006 Posts: 48 Junior Member | | Junior Member Joined: Dec 2006 Posts: 48 | I saw the hole in the fender for this brace. I will make them. That doesnt explain the brackets for sale on brads site.
I also see the signs of 2 holes (possibily rivits) at the top of the fender also. Anyone know if you need a brace up there? | | |
