1 members (Rnl364), 104 guests, and 6 robots.
Topics128,077
Posts1,056,033
Members48,433
#223548 01/05/2007 12:20 PM
What problems are to be expected fitting a 270 into a 39 or 40 pickup?
I think I've read that the radiator has to be moved forward due to the extra length of the GMC engine. Is this right,& what is involved regarding hood modifications etc? Are there any alternative solutions? I'm not concerned about running gear adaptions, as long as it is realistic to physically fit the engine into the engine bay.
Do the same problems exist in the heavier trucks of the same years?
Thanks - (all enquiries for a future project)
#223549 01/05/2007 9:25 PM
If you check the tech tips on this site there is quite a bit of info about putting a 302 (270 is physically the same) into Chevy trucks.
#223550 01/05/2007 9:43 PM
283 is much shorter
Another quality post.
Real Trucks Rattle
#223551 01/06/2007 12:13 AM
Here are some lessons learned I wrote up after putting a '55 235 into my '40 GMC:
http://oldgmctrucks.infopop.cc/eve/forums/a/tpc/f/462107036/m/4471020781
Steve
See my 1940 Canadian GMC:
http://community.webshots.com/user/ndnchf
#223552 01/06/2007 1:58 AM
He didn't ask about a 283 and there's a lot of difference between putting a short motor in a long engine bay and putting a long motor in a short engine bay.
Ken, here's a link to the Tech tip Old Sub mentioned.
If you haven't already, join the discussion group at oldgmctrucks.com
There's a guy there running a 302 in a '37 Chevy truck.
#223553 01/06/2007 7:42 AM
Thanks fellas
Rusty - I'm not anti-V8, but I'd go 270 for this project to stay closer to original & still have reasonable pulling power.
We've got several 270's lying around just waiting for a use.
I've joined over on oldgmctrucks.com - Thanks Cletis, I'll search through - excellent site there too
#223554 01/07/2007 8:02 AM
Let us know how it comes out, I'm about to put a GMC 302 into my '50 1/2 ton. I'm excited. I'm probably going to put a Howard log manifold on it, I have a set of Holley 94's in my garage just waiting for a home.
Paint & Body Shop moderator
