| | | Forums66 Topics128,161 Posts1,056,957 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 37 Apprentice | | Apprentice Joined: Nov 2006 Posts: 37 | This truck was for sale on the web from a car auction place in St. Louis. I made a deal on it but someone beat me to it. Loosing out on the deal inspired me to build my own. I go back to these pictures every time I hit a snag. I sure would like to pick the brain of the guy that built this one though. Do you think he is out there in Stovebolt land? John 40 Chevy that got away | | | | | Joined: Aug 2005 Posts: 183 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 183 | The only thing I don't like about it is the grill top chrome is painted over where the Chevrolet script is. Otherwise a real nice truck. | | | | | Joined: Nov 2006 Posts: 37 Apprentice | | Apprentice Joined: Nov 2006 Posts: 37 | I would just like to know if they had to move the engine location backwards. I really didn't want to do that if I could help it. | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Looks like that's sitting on a late 80's 4x4 s10 or blazer frame judging from the dash they used, and the stock 4wd/2wd lever in the floor.
| | | | | Joined: Nov 2006 Posts: 37 Apprentice | | Apprentice Joined: Nov 2006 Posts: 37 | Yep Fumblin its a 88 with a 2.8 V6. Mine is a 2000 with a 4.3 V6. My clutch fan sticks way out there. Maybe if a do away with it and put an electric fan in front... | | | | | Joined: Dec 2002 Posts: 3,445 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,445 | Nice looking truck, and it appears to be put together pretty well... i wonder why they didnt spend a bit more time on the inside of the bed?
| | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | I don't see how a v6, no matter how long the fan clutch, could be longer than the original I6. | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | Might not be longer, but may be positioned farther forward in the modern frame. Should be easy to move though. move existing mount work, then shorten the driveline.. | | | | | Joined: Nov 2001 Posts: 1,519 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,519 | The condition of the bed makes it look like its just a "camouflage" job. | | | | | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | Can't vote for the paint job. | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | The color isn't putting any starch in my shorts either, but I have to approve of the project as a whole.
They for the most part kept a pretty much bone stock look to the truck.. and the condition of the bed wood suggests they built it not just to be flashy and cool, but also as a driver and working truck.
It's something i'd like to do with a '41 thru '46 or a '47 thru '50 truck.. keep it as bone stock looking as possible, but have modern conveniences like power brakes and steering, more modern drivetrain, and 4wd.
Not sure i'd bother with the 2.8 V6 tho.. but that 4.3V6 is one heck of a engine.. and darn near bulletproof.
Sure would have been nice if the person who built that truck had provided a 'blow by blow' of the build for us guys who'd like to travel down that path.
| | | | | Joined: Nov 2006 Posts: 37 Apprentice | | Apprentice Joined: Nov 2006 Posts: 37 | They did refer to the truck as a "work truck" with good gas milage and not a street rod or antique. I can only move the engine back about two inches before the transfer case hits the cross member for the torsion bars. | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Originally posted by 40ChevyS10: They did refer to the truck as a "work truck" with good gas milage and not a street rod or antique. I can only move the engine back about two inches before the transfer case hits the cross member for the torsion bars. How are you fixed on width? I'd like to do a simular project with a '41 thru '46, and it was my understanding the only difference between '41 thru '46 and the '39 and '40 trucks was the cabs on the '39 and '40 trucks are a bit shorter. There are likely to be a whole lot of differences between an '88 s10 and a 2000.. hell, i've owned a '91 and a '98 and they ain't even the same truck. So your only obstacle at the moment is your clutch fan sticks out too far? I don't have a 2000 4.3 sitting around to look at, but couldn't you just replace it with one that doesn't stick out that far? Maybe one from an earlier year engine? You might measure how far yours sticks out, and determine how much shorter you need it to be and then go peek at the engines of earlier s10's at the u-pick-it bone yard.
| | | | | Joined: Nov 2006 Posts: 37 Apprentice | | Apprentice Joined: Nov 2006 Posts: 37 | The late 47 thru 54 would be a better fit with their wider cab and fat fenders. The 40 cab makes a nice fit on the back corners but gets tight at the front. I have about two inches of the S10 frame peaking out on each side at the front corners. The fenders will cover that up though. The bigger issue is the hugh amount of space left between the back of the engine and the front of the cab. The clutch fan extends about five inches forward of the radiator core support. I got a 16 inch wide radiator made that I can stick way out behind the grille but it's gona look like Frankenstine under the hood if I leave it like this. | | |
