2 members (pdlightning, Tronman), 104 guests, and 3 robots.
Topics128,094
Posts1,056,064
Members48,433
#223093 12/31/2006 2:09 AM
Anybody know how to adjust fog light, the kind that fit with a bracket on the bumper braces? This is on a '40. Mine give off light fine but direct it to the top of the trees!
40 Chevy 1/2 ton
#223094 12/31/2006 2:32 AM
Yes.
I wasn't actually gonna write any more, but 'tis the season to, etc., so here it is: There's a nut you can see from behind the light down low on the housing. Loosen it off thoroughly, tilt the light downward while pulling up on the bezel. Tighten the nut and check the aim, then repeat until you're satisfied.
1951 3800
-hotshoe
#223095 12/31/2006 2:58 AM
25 feet from a wall on level ground, measure up to the center of your fog light. Make 2 marks this height on the wall and center your beam on the marks.
#223096 12/31/2006 3:11 AM
Thanks blu, but my problem is I don't see how to make the adjustment. Everything looks fixed to me.
40 Chevy 1/2 ton
#223097 12/31/2006 4:00 PM
Guess I was spacing yesterday and didn't notice your post hotshoe36. I'll give it a try. With both yours and blu 64 posts, I should be good to go. Thanks!
40 Chevy 1/2 ton
#223098 12/31/2006 4:38 PM
Ex Hall Monitor
Ex Hall Monitor
Quote
I wish all of the idiots that like to run fog lights all the time would follow that advise. I get SO tired of being blinded by out-of-adjustment fog lights. :mad:
#223099 01/01/2007 2:38 PM
Yeah, everybody wants to aim them too high.
#223100 01/01/2007 3:53 PM
Tiny, just get a big spotlight, that makes them turn the dam foglights off pretty quick. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
