| | | Forums66 Topics128,090 Posts1,056,018 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Anybody know how to adjust fog light, the kind that fit with a bracket on the bumper braces? This is on a '40. Mine give off light fine but direct it to the top of the trees! Thanks
40 Chevy 1/2 ton
| | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | Yes.
I wasn't actually gonna write any more, but 'tis the season to, etc., so here it is: There's a nut you can see from behind the light down low on the housing. Loosen it off thoroughly, tilt the light downward while pulling up on the bezel. Tighten the nut and check the aim, then repeat until you're satisfied. 1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: Jan 2005 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 112 | 25 feet from a wall on level ground, measure up to the center of your fog light. Make 2 marks this height on the wall and center your beam on the marks. | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Thanks blu, but my problem is I don't see how to make the adjustment. Everything looks fixed to me.
40 Chevy 1/2 ton
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Guess I was spacing yesterday and didn't notice your post hotshoe36. I'll give it a try. With both yours and blu 64 posts, I should be good to go. Thanks!
40 Chevy 1/2 ton
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Originally posted by blu 64: 25 feet from a wall on level ground, measure up to the center of your fog light. Make 2 marks this height on the wall and center your beam on the marks. I wish all of the idiots that like to run fog lights all the time would follow that advise. I get SO tired of being blinded by out-of-adjustment fog lights. :mad:
| | | | | Joined: Jan 2005 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 112 | Yeah, everybody wants to aim them too high. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Tiny, just get a big spotlight, that makes them turn the dam foglights off pretty quick. Brian | | |
