2 members (Millenimech, klhansen), 161 guests, and 1 robot.
Topics128,115
Posts1,056,289
Members48,439
#222862 12/28/2006 8:21 PM
I own a 1957 3100. The driver side window wont stay up.It slowly creeps down. :confused: What do I need to repair/replace? I need to replace the glass and the vent frame and window anyway so I can make this repair when I do that. So what do I need to do so the window stays up once I fix the glass? Thank you.
#222863 12/28/2006 10:52 PM
Riding in the Passing Lane
You need a new window regulator. They are available from most specialty suppliers like American Classic.
1972 Chevy c10 Cheyenne Super
#222864 12/28/2006 10:54 PM
maybe new tight felt channels would fix it, if you're replacing those when you pull it all apart, but it sounds like the regulator is worn - when you have it out for a look might be able to mash a rivet tighter on the regulator mechanism
#222865 12/28/2006 11:31 PM
Thank you gentlemen. I thought maybe it was the regulator but wasnt sure. I dont want to go to the work of replacing glass and then just watch it creep open again. I have done so much business with Classic Truck Parts of America, they should know me by my first name! grin
#222866 12/28/2006 11:50 PM
you can install the window crank handle so if the window starts working down it has to lift the crank that has helped in some applications...doc
#222867 12/28/2006 11:51 PM
Kev,
For a somewhat temporary fix while you wait for parts you could also check the position of the window crank handle. Reposition it so the weight of the crank will pull down on the regulator to pull the window up as you drive along rather than pull it down if it 180 degrees opposite. I seem to remember a thread about this a while back, not sure which forum it was in though.
Steve
'49 3800
'52 3600
'57 3100
#222868 12/29/2006 1:06 AM
Ex Hall Monitor
Ex Hall Monitor
doc41 is correct if the window doesn't work it's way all the way down. I fixed a ton of vehicles that the window wouldn't stay up by positioning the crank handle to where gravity is pulling the handle in the close direction.
#222869 12/29/2006 3:36 AM
Hey doc, that's one of those things that makes you say, "Now why didn't I think of that?"
Ralph Davis
1970 Chevy C10 Webshots
My Stovebolt Gallery page
Old trucks never die, they just find a new home.
#222870 12/29/2006 5:48 PM
Thanks guys. Thats a great idea. I will do that tomorrow morning. Its supposed to be warm for one day and I plan to drive "RT" some around town. grin
