5 members (Randy Baumann, TexasJim50, 52Carl, dt235sd, 1955 1 Series), 77 guests, and 5 robots.
Topics128,014
Posts1,055,324
Members48,419
#22257 09/09/2004 11:53 PM
Junior Member
Junior Member
My 58' 235 locked up on me. Unsure of the engine history. Should I look for a new engine or should I have it rebuilt? I'm probably going to switch out the rear end so its not so low geared. Any recommedations?
#22258 09/10/2004 12:49 PM
How about you rebuild it? A few books and some time and you can probably do it. Have someone else do the head work. What have you got to lose?
As far as the rear? I keep hearing GM 10 bolt out of a 2nd gen F-body...like Camaro or Firebird.
Not sure for your 58 tho.
#22259 09/10/2004 1:49 PM
GV: I am running a complete 1969 Grand Prix axles and rearend. 3.55 gears matches up perfect.
popcorn The Truth is Out There (Get your tape and measure twice)
#22260 09/10/2004 7:45 PM
You won't find a "new" engine that will drop into your truck without some modification. Usually you can rebuild the 235 block.
Did your engine lock up from setting, or while driving. If it's from rust and setting, there is a good chance of freeing her up.
Fred
52 3600
69 C-10
#22261 09/10/2004 10:26 PM
Junior Member
Junior Member
It locked up while driving. I wasn't sure what was wrong so I tried to turn it over, but it sounded like it had taken my exhaust manifold off.
