2 members (gswbbc, wilbur53), 139 guests, and 3 robots.
Topics128,035
Posts1,055,446
Members48,422
#222579 12/24/2006 4:54 PM
I have a 1946 Chevy Truck and was wondering where the spare tire was normally carried on the truck?
Dan Mascheck
Wharton, TX
#222580 12/24/2006 5:21 PM
The spare is usually under the bed.
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
#222581 12/24/2006 11:38 PM
46Dan,
Check out Jim Carters. They have the complete under bed carrier. It is around $250 or something like that. I have only seen one or two on E-bay since 03. They were a common item to remove and throw away. I am guessing most folks with trucks did not want to crawl in the mud to get at the spare.
I see it in new trucks that are in service duty..the spare rides in the bed to avoid getting full of snow and mud up in these parts..
#222582 12/25/2006 12:12 AM
On my ¾ ton, which has an extra stake pocket, one of the previous owners welded a bracket between the front and center stake pocket. The tire is bolted to the bracket and rides on the running board.
Stake pockets are available at several of the vintage parts places, wonder if a person could buy a stake pocket, welded it to the bed side and mount the spare to it.
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
#222583 12/25/2006 2:59 PM
Thanks for the help. I will call Carter's Wednesday and check. Most new trucks I know of today have the tire underneath, whether you like it or not.
I would have thought they would have had a side mount carrier on the outside behind the driver like many old trucks.
Another wierd quirk is, why is the gas filler tube on the passenger side instead of the driver side?
