| | | Forums66 Topics128,050 Posts1,055,753 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 110 | I have a 1946 Chevy Truck and was wondering where the spare tire was normally carried on the truck?
Dan Mascheck Wharton, TX | | | | | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | The spare is usually under the bed.
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
| | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | 46Dan,
Check out Jim Carters. They have the complete under bed carrier. It is around $250 or something like that. I have only seen one or two on E-bay since 03. They were a common item to remove and throw away. I am guessing most folks with trucks did not want to crawl in the mud to get at the spare.
I see it in new trucks that are in service duty..the spare rides in the bed to avoid getting full of snow and mud up in these parts.. | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | On my ¾ ton, which has an extra stake pocket, one of the previous owners welded a bracket between the front and center stake pocket. The tire is bolted to the bracket and rides on the running board.
Stake pockets are available at several of the vintage parts places, wonder if a person could buy a stake pocket, welded it to the bed side and mount the spare to it. | | | | | Joined: Nov 2006 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 110 | Thanks for the help. I will call Carter's Wednesday and check. Most new trucks I know of today have the tire underneath, whether you like it or not.
I would have thought they would have had a side mount carrier on the outside behind the driver like many old trucks.
Another wierd quirk is, why is the gas filler tube on the passenger side instead of the driver side? | | |
