0 members (),
135
Mod | | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 28 | Anybody got any ideas about putting a tilt column and a turbo 350/400 in my 66 C-10. Its got a three on the tree now and shifting sucks! (im a trucker by trade...ive had enough by the end of the 15 hr day, thank you very much) The coulumn i have is out of an 87 chevy p/u and need a shopping list so i can go visit the junkyard. Any tips or directions would be good. thanks! | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | The 66 was offered with an automatic (powerglide) which has the same dimensions as a turbo 350 so the trans should be a bolt in. The easiest column would be a 67-72. The tilt version is getting a little hard to find. Lots of newer columns have been put in but the tube is larger in diameter and a dash bracket and floor anchor need to be fabricated. I tried to put in a picture of a 66 but, no luck. You can see a factory auto setup in one on my photobucket site-- http://s32photobucket.com/albums/d41/coilover/ Go to page 2 and scroll down to the red 66 stepside. Good luck
Evan
Evan
| | | | | Joined: Jan 2005 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 112 | I have done this swap. Column out of a 67-72 is easy. Columns out of 70s-80s vans are the same. If you are running a long tailshaft 3-speed, use a short shaft turbo 350 and driveshaft length will stay the same. If your 3-speed is the un-synchro low gear, you will have to change front yoke. You will have to cut the crossmember where the old bellhousing sits,for clearance. Rear mount will work on crossmember where e-brake mounts. Many ways to go with coolers. If i can help just holler. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I once had a '66 that was a factory Powerglide. The parts from that truck would be exactly what you need for a Turbo 350. My brother made the swap on a similar truck, and if memory serves it was a simple bolt together swap.
He used the original column and shifter with no trouble. I have a '72 with a tilt column and automatic. You can't have my parts, but again, they would be just what you need if you can find one.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Dec 2006 Posts: 3 Junior Member | | Junior Member Joined: Dec 2006 Posts: 3 | I've done a few of these swaps, it's all a bolt in deal. Transmission crossmembers thru 72 fit right in. The late 70's van columns fit these trucks like they're made for'em. Use an intermediate shaft from a 69-72 pickup and shorten it to fit or cut your shaft to fit and connect it with a steering u-joint or coupler.
Frank | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | Hey Peyvinetrans...I put a mid 80's column in my 64 Suburban and it was no sweat. Use the factory 64 column under dash bracket and drill as needed to bolt the newer column to it...then bolt up under the dash..easy. I also used the 64 firewall floor anchor. I found that an 80's Oldmobile steering extention worked out great. It fit the column splines, and was adjustible in length...perfect fit, no welding needed! If you don't come across one of these, you can use a early to mid 70's extention, but it must be cut and welded to length you need. Last, I presume you would like PS? Get the bracket kit and then use the early to mid 70's PS box. It was very easy. The first one I did and just went smooth as glass. | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | Um, duh? I just realized who you are Pevinetrans. Good job on the purchase of this truck...looks like a great one, and I'm with your wife, stock color of red is pretty awesome. Call me if you still have the number or email [email protected] if you have questions about the column and tranny. Happy to answer any. Merry Christmas~! Tom | | | | | Joined: Dec 2006 Posts: 22 Apprentice | | Apprentice Joined: Dec 2006 Posts: 22 | Pevinetrans:
Before you go to a junkyard, send me an email. I've got a 58 Apache that I am putting a 700r4 in that had a T350. It's in excellent shape and you can have it cheap. Best part is I am in Glendale, AZ
Fleetside Bob
