1 members (UtahYork), 215 guests, and 1 robot.
Topics128,101
Posts1,056,181
Members48,436
#222422 12/21/2006 9:02 PM
any suggestions for how the average Joe could "re-size/re-bore" the new pedal bushings to fit the pedal shaft?as they are a good bit too thick. I am also finding that they fit a bit loose inside the pedal assy (ie can be turned by hand).
#222423 12/21/2006 9:46 PM
PNR123,
I guess this thought would depend on how much material needed to be removed from the ID of the bushing. They make Loctite retaining compounds you could 'glue' the bushing into the bore with...but..if you created heat when you honed the ID, it might come out.
If I were to do this myself, in the garage with limited tools, I would epoxy the bushing into the bore, then use a brake hone to fit the ID to the OD of the shaft.
This is real low tech, so you might end up with a sloppy feeling set of pedals. If you want 'nice and tight', a local machine shop could help you out.
Stuart
#222424 12/21/2006 10:08 PM
I would think your local bearing shop would be able to supply you with the correct bearing. Just measure your parts, I.D. and O.D. and length.
#222425 12/21/2006 11:23 PM
on my 39. new bushings from online vendor. close but not original. new shaft made at machine shop. pressed out old bushing using a carriage bolt with nut and washer to pull. pressed new bushing in using machinist vice from drill press. machine shop honed the new bushing to fit the new shaft, i drilled and tapped pedal for grease fitting. machinist charged me $20 or so. good old Joe Rolland.
"It ain't a truck if you can't hose out the cab."
#222426 12/22/2006 9:09 AM
I used a brake cylinder hone to fit the sector shaft bushings in a steering box and it fit good and held up for a long as I had the Jeep I did it on, no reason you couldn't do that with a set of pedal bushings, just sneak up on the bore you need and make sure to keep the hone moving so you don't get a tapered bore.
On the fit in the bore, chances are the old bushings were slipping and wore the inside of the housing. You will want to get oversized bushings, epoxy won't hold up. You could also try swedging the outside of the bushings you have but it may not work too well long term.
Paint & Body Shop moderator
#222427 12/23/2006 9:00 PM
Just to update....
I got everything sorted by a pal at a machine shop. The shaft itself had quite a groove worn into it by the clutch pedal lever ,probably from never seeing any lube. So my pal and me decided that we'd turn down the shaft to fit the bushing and ended up taking off about .035" and now everything fits great and is all even and round and darn near perfect , thanks all for the suggestions
