| | | Forums66 Topics128,049 Posts1,055,679 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 108 | I recently bought a 51 and have been working on it for the last 2 months to make it my daily driver....Question is...it has no key hole on the drivers side...the passenger side has one...now in 51 did they not make a key hole there or did somebody fill it in... | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Holcomb, no key on drivers side, it was thought it was safer to slide across the seat and exit and lock the passenger door while standing safely on the curb, hope that helps. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | don't think there was any GM truck till the 60's that had a driver side lock standard - onea lifes little mysteries Bill | | | | | Joined: Oct 2006 Posts: 125 Member | | Member Joined: Oct 2006 Posts: 125 | for more input, run a search, as there are several previous threads on the door lock mystery...
Carl
'58 3600 350/4-sp/stepside/big window cab '59 3100 235/4-sp/stepside
| | | | | Joined: Nov 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 108 | Wow...so if you have a baby seat in the front seat...wow...good thing I lost some weight.. thanks guys.. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | Back in 1951 gentlemen driver's ruled and always allowed the passengers to access the cab first. they then unlocked the doors.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Sep 2006 Posts: 37 Apprentice | | Apprentice Joined: Sep 2006 Posts: 37 | I am attempting to add a key lock to the drivers door on my 49 and found that the drivers latch mechanism does not have the same internals as the passenger side. I bought a used passenger door latch to see it I can use parts from it to modify the drivers latch so it will interface with the key lock. I haven't had the time lately to pursue it further. I'll let you know if I have any success. | | |
