5 members (Gdads51, 78buckshot, Opelika Tom, klhansen, 1 invisible), 122 guests, and 3 robots.
Topics128,062
Posts1,055,847
Members48,428
#222092 12/18/2006 5:54 AM
I recently bought a 51 and have been working on it for the last 2 months to make it my daily driver....Question is...it has no key hole on the drivers side...the passenger side has one...now in 51 did they not make a key hole there or did somebody fill it in...
1951 3100
http://community.webshots.com/user/HolcombRacing11
"Every child is an artist. The problem is how to remain an artist once he grows up."
Pablo Picasso
#222093 12/18/2006 6:06 AM
3B Offline
Hy Holcomb, no key on drivers side, it was thought it was safer to slide across the seat and exit and lock the passenger door while standing safely on the curb, hope that helps.
#222094 12/18/2006 6:33 AM
don't think there was any GM truck till the 60's that had a driver side lock standard - onea lifes little mysteries grin
#222095 12/18/2006 8:12 AM
for more input, run a search, as there are several previous threads on the door lock mystery...
Carl
'58 3600 350/4-sp/stepside/big window cab
'59 3100 235/4-sp/stepside
#222096 12/18/2006 3:15 PM
Wow...so if you have a baby seat in the front seat...wow...good thing I lost some weight..
thanks guys..
1951 3100
Pablo Picasso
#222097 12/18/2006 6:53 PM
Back in 1951 gentlemen driver's ruled and always allowed the passengers to access the cab first. they then unlocked the doors.
Jim & Caroline
#222098 12/18/2006 7:00 PM
Apprentice
Apprentice
I am attempting to add a key lock to the drivers door on my 49 and found that the drivers latch mechanism does not have the same internals as the passenger side. I bought a used passenger door latch to see it I can use parts from it to modify the drivers latch so it will interface with the key lock. I haven't had the time lately to pursue it further. I'll let you know if I have any success.
