| | | Forums66 Topics128,181 Posts1,057,189 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 18 Junior Member | | Junior Member Joined: Feb 2004 Posts: 18 | I have been searching for a while and I found a collector that may be willing to sell me one of his.
It is only missing a couple bumpers, but the truck is straight, has no rust and is all original.
We reached a deal on the price of $2000 Cdn, do you think this sounds about right? Or is it too high?
The truck is a 3/4 ton long box right now, I plan on shortening the box when I retro it.
thanks az | | | | | Joined: Jun 2006 Posts: 382 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 382 | Sounds pretty decent for the money. I am in the process of paying off a 51 3/4 ton Chevy. The owner & I agreed upon $1700, pretty much the same condition. He was also asking $2000. So, I think you are right in the ballpark. By the way, I have the same plans for this truck as you do yours. | | | | | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | A completely stripped cab without doors is worth that much if it truly has no rust.
Mike Barnes 1950 GMC 1-ton pickup
| | | | | Joined: Oct 2005 Posts: 11 New Guy | | New Guy Joined: Oct 2005 Posts: 11 | No rust is key ! Sounds pretty good.
'51 Chevy 3100
| | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | Thats a good price up here AlZ.
Go for it. | | | | | Joined: Nov 2006 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 60 | A GOOD PLACE THAT I GO TO SEE IF A PRICE IS ABOUT RIGHT HERE IN CENTERAL USA IS TO GO TO www.modelthaven.com AND LOOK TO SEE WHAT HE HAS AND WHAT HE IS ASKING FOR IT. MOST EVERYTHING THERE IN ALMOST RUST FREE AND IF THERE IS ANY BODY DAMAGE HE WILL TELL YOU. HOPE THIS HELPS. GOOD LUCK. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Question. Out of curiosity why would you want to go to the trouble of shortening the 3/4 ton? I think they look fine as they are. Probably more rare too. | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | I second that, olblu. Keeping mine long and lean...
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
