3 members (TUTS 59, thekid1950, Peggy M), 40 guests, and 8 robots.
Topics128,012
Posts1,055,320
Members48,419
#221747 12/14/2006 2:27 PM
I have a 71 auto column in my 64 that is hard to pull to you to put it in gear, but only when the temps are below 60Degrees. Works fine in warmer weather. Any ideas?
#221748 12/14/2006 2:51 PM
If it is anything like the ones I have had, the 30+ y/o lithium grease is all hard & gummy at lower temps. I have pulled the wheel & metal shrouding on the column to clean out the old grease & add a little new stuff. I bought a 69 C10 that had sat for 4-5 years, engine fired right up w/a hot battery, but I had to clean the column to get it to shift-the shifter wouldn't move at all. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#221749 12/14/2006 3:32 PM
I had a 72 three on the tree that the previous owner had took apart and greased, couldnt even shift it in cold weather, took it back apart and cleaned it, loaded it with graphite powder, shifted like a dream after that!mabe the powder would disseapear after awhile but i sold the truck 3 years later and never had another problem...just my thoughts.tom
