| | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 112 | I have a 71 auto column in my 64 that is hard to pull to you to put it in gear, but only when the temps are below 60Degrees. Works fine in warmer weather. Any ideas? | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | If it is anything like the ones I have had, the 30+ y/o lithium grease is all hard & gummy at lower temps. I have pulled the wheel & metal shrouding on the column to clean out the old grease & add a little new stuff. I bought a 69 C10 that had sat for 4-5 years, engine fired right up w/a hot battery, but I had to clean the column to get it to shift-the shifter wouldn't move at all. Brian | | | | | Joined: Sep 2006 Posts: 206 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 206 | I had a 72 three on the tree that the previous owner had took apart and greased, couldnt even shift it in cold weather, took it back apart and cleaned it, loaded it with graphite powder, shifted like a dream after that!mabe the powder would disseapear after awhile but i sold the truck 3 years later and never had another problem...just my thoughts.tom | | |
